SIdmouthsteve
- Jun 30, 2022
- 22
I start the Inverter then start the battery and it all looks good with green lights and blue lights on on the battery packs. Then 5-10 minutes later I get warning 19 (Battery disconnect) and the lights on the battery turn off.
System:
Growatt Ark 10.25L-A1 battery with BMS and SPF 5000 ES inverter
Solar panels not yet fitted.
The battery is 60% charged.
Inverter is set to:
01: SBU
02: CHG1 10A
05: bAtt Li (use Ark BMS)
The rest of the options are default because this is a test of battery charging before installing solar panels.
Any ideas?
System:
Inverter is set to:
01: SBU
02: CHG1 10A
Any ideas?
