Old_Skewler
Very exciting, I believe I am making (slow) progress with my installation. I have been able to connect Generator to Inverter + Inverter to AC Subpanel. Yeah!!Everything is working so far: the inverter is reading the 240V from generator correctly and I am getting the correct 240V out in the subpanel.
Before I continue to the next step, I need to confirm/verify that the inverter is charging the battery when generator is running and I can't tell from the display whether the battery charger is working.
Could someone with the same GroWatt DVM-MPV AIO inverter clarify how to read the display and verify if the battery charger is working correctly?
My Off-grid setup is the following:
- (1) 12kW Split Phase Generator located outside in a shed
- (1) 8kW Growatt AOI Split Phase inverter coupled to (1) EG4 100Ah Battery located in the same shed as generator
- (1) 100A Split-Phase panel inside the cabin with most loads wired 120V
I have made a video scrolling thru the Inverter display but I don't know how to add a video to the forum.
