maple_syrup
- Sep 13, 2022
- 5
Hi All!
This is my first setup - a Growatt 3000TL LVM-48P with a LifePower4 100ah 48v battery. I picked it up used on FBM from someone who purchased it a few months back (I have their receipt from Signature Solar) but never hooked it up.
I believe they hooked up the inverter to test it a few times, as the battery has reached its low-voltage cutoff. I am able to turn on the battery, get the Growatt to wake up before it trips the cutoff and everything shuts off.
I'm still working to get my solar mounted, this morning I was reading about 60V at PV-in, which I believe should be sufficient, but it wasn't enough to wake up the Growatt. I'll try again when the panels are in direct sunlight this afternoon. I don't have enough time to make sure the settings prioritize grid charging, otherwise I'd post my settings here.
My main question is:
Is there a way to charge from utility using the Growatt in this case? I have a socket hooked up to the AC Input, but plugging it in to my utility (on-grid) outlets does not wake up the Growatt to charge the battery. Reading the manual I did not find a good answer if this is possible.
If not, what are some good options for getting the battery back up to a safe SOC?
