Growatt Inverter and Battery
thejackal
Hi , I have a Growatt Inverter and I have some questions I hope you can help me with about the info in the display panel .
Today I checked my inverter in about an hour before sunset , and then I looked at the display and I saw this at the first time :
Again half-Hour before sunset :
after 5mins from the previous image:
So what does these number mean in the charging state and battery consumption ? can anyone please explain it to me ?
Notes:
1- The CHG led indicator is not blinking in all cases , I think this means that the batteries are Fully Charged
2- The Sun is still up and I have no idea why would it use the batteries in last half hour before sunset?
3- The electricity is off now that's why the AC/IN icon is not showing and the AC/IN led indicator is blinking
Anyone ?
Please I need to know what the diagrams on the screen really mean ? specially in the last two cases of battery using .
Regards
Image 1 shows power from the PV powering loads and charging the battery.
Image 2 shows both PV and battery powering loads.
Image 3 shows the same as image 2.
For example in 2nd image the current is 0.0A , so does really use the battery or no ?
Just because it says 0.0A does not necessarily mean zero amps. It may be the current is just lower than the 100mA minimum value the display can show. IOW a low amp trickle current.
Bear in mind the accuracy of these monitors at low current levels isn't great.
thanks for the great info mate, this explain everything .
