Hi All!
I own an SPF5000ES with the newest 067 and 068 firmware.
Battery connected via CAN, LIFEPO4.
Everything works fine, except one thing.
I defined SBU, so the utility only as last chance.
Also the battery can be charged only solar option choosen.
The question:
In the evening my battery goes down around 50%.
Solar charges it till 11-12AM fully.
The battery are fully charged and then starts what I don't understand.
Solar has enough power to feed everything, even more as needed.
But the battery is contionusly drained with a little ampere somehow.
Seems to me, that the inverter powers itself from the battery.
This means for the evening when solar is away, the battery already drained to 98-97%.
Is it somehow possible to eliminate this and force growatt inverter not to use the battery at all when solar is available?
Thank you!
