Hello, I have 5 Growatt SPF 5000es working in three phase system. I have 5 Rosen Powerwall 48v 150ah. Everything is working well including the BMS communication with the batteries. Each battery has a charging ampere capacity of 150ah but unfortunately, the growatt inverters are throttling the charging capacity ampere. It only charges the batteries at 20A per inverter that makes a total of 100A but when I change the program 05 to "US2" instead of "LI", the charging goes up to a 100A per inverter. Any ideas on this problem?
