MT off grid
- Jan 23, 2022
- 571
Am I allowed to have two grounds in the same hole on a ground bus bar? Thought about adding a second bus bar and running a 6awg wire to connect them but wasn't sure which way to go
It depends on if the bar is rated for multiple conductors per connection, as far as the NEC goes.Am I allowed to have two grounds in the same hole on a ground bus bar? Thought about adding a second bus bar and running a 6awg wire to connect them but wasn't sure which way to go
But it won't hurt anything if that's what you are asking.
I wouldn't worry about it. I just had to say what I said. In case someone wanted to know what the code was.
Two grounds at the same time is not a good thing.
But for now, you'll only be using one or the other.
Right?
Right?
Right?
Two
Right?
YupI showed him my chicken scratch instructions and he was still a bit lost, did I write the instructions correctly?
They always have, kinda sorta. lolI thought so, was doing some read8ng that these new growatts have the NG bond done with a relay internally but can't seem to get confirmation on that and my testing shows its not true, guess the neutral bond is my only option at this point
