timselectric
- Feb 5, 2022
- 18,530
I wouldn't.Are you familiar with the bluesea 6006 battery switch? It says it's rated for 48 volts. Lithium is up to 58 volts, I contacted bluesea and I was told that I should not use it with lithium due to the higher voltage, they said they are working on a higher voltage switch but I already own several of them now, I see lots of people using and recommending these switches but seems a bit risky, do you think a 48 volt switch that is good for 300 amps would be safe to use for 58 volts?
