Hi All, my Father has an SP2000 + GBLI5001 (+ Sonnenmacht blue/grey inverter). It is showing error 116 & BMS COM Fault. The installer is no longer trading, but my father was able to contact GroWatt, who said (what is says in the manual) to restart the system. I believe he has done this, but after reading the manual it says to disconnect the battery (I tink). Can you confirm to restart, the Wylex breaker is switched off followed by the two Socomec switches? Does any of this disconnect the battery, does it have to be disconnected, I couldn't see how to disconnect the battery without taking off the front panel of the SP2000? When I was last at my Dads, the connecting Ethernet cable (SP2000-battery) seemed OK, disconnecting it did seem to affect how the SP2000 responded to pressing the "reset" button on the side of the battery, as far as I can remember. Any advice please? All the best, S.P.
