Hi Everyone,
I just started building my first off-grid solar system and I purchased a Growatt SPF 3000TL LVM-24P hybrid inverter and a 24v BYD LFP 3.5kwh battery pack. When I connected the battery cables and turned on the inverter it turned on but there was no light on the LCD. When I tried to turn off the inverter it wouldn't shut down. The fans kept running, so I had to turn off the circuit breaker on the battery. When I looked at the specs on the side I noticed that it says Battery input 48vdc. Isn't this model supposed to use a 24v battery?
