Dank Farrik
- Feb 1, 2022
- 155
I’m thinking about building a home power station with 2x 48V rack batteries (EG4 or SOK). Questions for the Growatt experts here regarding the Growatt SPF 3000TL LVM 48V:
1. For Setting 5 (Battery Type), if it’s set to “Li” (battery with Growatt BMS communication), Setting 2 (Max utility + solar charge current) says this:
“(If Li is selected in Program 5, this program can’t be set up)”
Why is this? What if I want to set a max current limit for solar charging?
2. If Setting 5 set to “USE” (User 1) or “US2” (User 2), does the Growatt display still show battery SOC %, or just the battery voltage?
3. In Signature Solar’s product video for the Growatt, they mentioned that you should keep the power switch in the OFF position, connect your batteries, then turn the power switch ON, otherwise the huge inrush current may damage the inverter. This implies that the Growatt has some kind of precharge circuit. Can anyone confirm?
Thanks in advance!
Thanks in advance!
