joshualeroy
- Nov 18, 2021
- 3
I've got two of these inverters, the BMS and the other inverter shows the correct voltage, but the one is off by 0.9-1 volt consistently regardless of charge level. The reading at the terminals of the inverter is consistent with the BMS and the other inverter. The batteries are LiFePo4. Is there anything I can do or does this thing just need replacing.
