thehackedone
- Jul 19, 2021
- 8
I saw this in a post, but I have my 19 set to 51 and still the big battery display only says 49.something, shouldn't it be leveling off higher then 49? Is this right or am I doing something wrong?
Also when it starts charging again the Growatt beeps and then the solar wattage goes and fluctuates all over the place is that normal too? I managed to turn the annoying beeping off but it keeps doing a beep then showing 19 over and over again. Does that just mean the battery is full?
I have another issue for you all... I am using about 300-400 watts off the inverter on this thing, as soon as I try and use 500-600 watts the inverter kicks off randomly for a split second and comes right back on.
Hi folks, I received the following info from BigBattery and thought I would post it in case someone is looking in this direction. This is from the 48V Off Grid System they packaged together over the past few months (
The number is the MENU SETTING in GROWATT #:
05=USE
12=44V
13=48V
19=50.4V
20=50V
21=42V
FLAMA-48053-G1 | 48V LAMA - LiFePO4-115Ah-5.3kWh | 1 |
SPF-3000TL-48P | Growatt Solar Inverter SPF 3000TL LVM 48P |
05=USE
12=44V
13=48V
19=50.4V
20=50V
21=42V
