Cheap 4-life
My body is 2.63 trillion volts, .07v per cell
In reverse, When the inverters internal N/G relay is open, then the N/C cube relay stays closed, which allows power from the load panel to go thru the cube relay and to the AT relay, which opens the N/C AT relay, stopping the AT from working?
So the power from the load panel to the cube relay (which is the signal for the AT relay to open) is supplied by the grid or the growatt depending on which one is powering the load panel?
