I have a SPF 5000 ES which is throwing an Error Code 52 and the inverter shuts down power to the loads. When I re-start the Inverter, the Error is cleared and the systems works for some time. I am using a Meritsun 100Ah battery and I do not think that there is a problem with the battery as it is working on LI mode using L01 protocol. However, the Inverter LCD shows very low battery voltage around 38V when the error occurs. Has anyone experienced this kind of an issue? If someone has and rectified the problem, would appreciate some advice.
