Martin70197
Hello community I have a situation with my Growatt SPF 5000 ES inverter.
The inverter does not produce solar energy. I can measure around 290 Volt but no current will appear on the display.
That is my configuration:
all worked fine for 2 months and I have no error code or error protocols on Shine
I tried only one of the 2 strings, still the same not working.
By the Way, the inverter works with the grid and Battery without problems.
Maybe somebody has an idea of how to fix this problem.
Kind regards and have a great weekend!!!
- Growatt SPF 5000 ES
- 12 Jinko 465 Bifacial Solar Panels in 2 Strings ( 6 per String)
Cable 6 mm² to the Combiner Box - 6 String PV Combiner Box with Lightning Arrester
- Cable 6 mm² to the inverter
- DIY Battery 16s with 280 AH with JK Bms
