Hi everyone,
The setup is as per the following them as per the following:
Is this a normal behavior?
My settings are as per the following:
- 2x SPF 5000 ES running in parallel (firmware: 040-06-104 and 041-06-104)
- 10x Longi LR5-72HPH-545M (each 5 panels to an inverter)
- 12x Lento lead acid LSTB-22000 (12V 200Ah) - installed each 4 in series (48V 200Ah) and then the 3 series in parallel resulting in a setup of 48V 600Ah -> 28.8 Kwh
- The whole system is also connected to the utility as well.
Program | Description | Left Inverter | Right Inverter |
1 | OPPR | SUB | SUB |
2 | CHGI | 50 | 50 |
3 | ACV | APL | APL |
4 | SAVE | DIS | DIS |
5 | BATT | USE | USE |
6 | LDRS | DIS | DIS |
7 | TMRS | DIS | DIS |
8 | OUTV | 230 | 230 |
9 | OUTF | 50 | 50 |
10 | BATN | 4 | 4 |
11 | ACI | 30 | 30 |
12 | B2AC | 46 | 46 |
13 | AC2B | 54 | 54 |
14 | CGPR | SNU | SNU |
15 | BUZZ | ON | ON |
16 | LCDB | ON | ON |
17 | ALAM | ON | ON |
18 | BYP | DIS | DIS |
19 | CV | 57.3 | 57.3 |
20 | FLTV | 52 | 52 |
21 | CUTV | 44 | 44 |
23 | PRLL | PAL | PAL |
28 | ADDR | 1 | 1 |
37 | YEAR | 2022 | 2022 |
38 | MON | 5 | 5 |
39 | DAY | 18 | 18 |
40 | HOUR | 10 | 10 |
41 | MIN | 0 | 0 |
42 | SEC | 0 | 0 |
43 | EQ | DIS | DIS |
44 | EQV | 58.4 | 58.4 |
45 | EQT | 60 | 60 |
46 | EQTO | 120 | 120 |
47 | EQI | 30 | 30 |
48 | EQ | OFF | OFF |
49 | CHG TIM | 0000 | 0000 |
50 | OUP TIME | 0000 | 0000 |
