Hello, I have two Growatt spf5000es Inverters. When I'm using the battery and the the voltage go below the set values its supouse to start to use the utility supply. And it use it for my loads, but invertors continue to use the battery for their supply. Do you know how I can set the invertors to use supply from utility only in that case? Thank you in advance.
