Julian-Indaiatuba
- Nov 5, 2019
- 45
Thank you again for your input. With the help of people like you, I am slowly learning about solar energy and how to install it myself.I remember I read these days many things about solar system calculations.
I cannot say where I found this or if it is correct but the rule of thumb for the fuses is 1.2 x nominal current for the string.
The fuses should be rated for 600Vdc.
Read more on https://sinovoltaics.com/learning-center/system-design/fuses-in-pv-systems/
or search for "choosing fuses for pv array/panel"
I think I have calculated all the fuses from the panels to the controller and the AC in and out. The one I find complicated thought is the fuse from the batteries to the charge controller, or is it from the chatge controller to the batteries?
Do I calculate the fuse amperage thinking of the Inverter’s maximum continuous output, or for the 5 second peak? These are questions I are difficult to find an answer to, which is logical I suppose as ever’s setup is slightly different.
Thanks again!
