hgg
- Sep 5, 2022
- 73
I am trying to decide between these two hybrid inverters. I already have the Phocos 3kW
which has been working fine until now with no issues at all but I need more power.
My PV installation is 3kW and I also have a DIY battery from 16 280K EVE cells with
a JK BMS.
Growatt: https://www.ginverter.com/products/spf-6000-es-plus
Phocos : https://www.phocos.com/product/psw-h-hybrid-inverter-charger/
Does anybody have experience with the SPF 6000 ES Plus or the Phocos 5kW?
My main requirements are:
1st) Fast transfer time from battery to grid and vice versa because I am running desktop PCs,
2nd) Clean inverter output (low %THD and minimal ground to neutral ac voltage)
3rd) Low idle current. (I will be using the SBU mode. AC utilization only when needed)
4th) Stable firmware. (Phocos 3kW has been running non stop for a year but the 5kW is different)
5th) My maximum power needs will be 3.5-4.0kW only during noon for an hour max.
Any help is appreciated.
Thanks.
a JK BMS.
Thanks.
