Traviss224
- Jun 25, 2022
- 294
It takes 2 legs of 120v ac input and 2 legs and neutral for ac output. Are you referring to post #7?
Ah yes, I see that the picture says it all. I was actually looking at my input and didn't see it as clearly as the photo. Thanks for the reply.It takes 2 legs of 120v ac input and 2 legs and neutral for ac output. Are you referring to post #7?
Thank you. Would you happen to know their various models output amperage of each inverter leg?If you are in US set hz to 60, I have the 6000t and if I was going to purchase again I would go larger maybe even 12k
I tested the 6000t and it shut down with overload at 3200 watts on one phase, after approximately 10 secondsThank you. Would you happen to know their various models output amperage of each inverter leg?
Sounds right. You have to size these things for the potential surge and not plan on running them maxed out for a long period of time. I have a 6000 W unit and I am mostly pulling 1 to 3K at a time on both legs combined with occasional surges that get me close to 2.5 and 3K on a single leg.A little update;
So I turned things on slowly to see what the break point would be.
I've 2x bar fridges, 2x large fridges and a dedicated freezer.
Everything ran and I could tell when the compressor motors would cycle as the inverters code 7 (overload) would flash and beep momentarily.
What pushed this over the edge and caused shut down were either the led lights in the garage or the fountain pump for a 130 gallon tiered water fountain.
Seeing how close this was, I've decided to really go big and get myself the 12kW unit. It's over kill but I know now that it should run with ease.
A fairly expensive lesson learned here both in time and money. But sometimes that's how it all goes.
I'll call Ian at Watt247 to see if he'll feel sorry enough to cut me a deal as I bought my current inverter from him
@Pete@SolarBatteryBarn I still get those data spikes. How do you update the firmware and where do you get it?It takes 240 volts AC input and can seamlessly go into utility/generator bypass when your battery gets low then switch back when the battery gets to the configured value.
I used to get data spikes on my monitoring app before I updated the firmware.
I now I wished I’d gotten the 8K model. As of now when I’m charging the EV the wife can’t make tea with the electric tea kettle without causing a fault. Because my kitchen has got a couple of multi-wire branch circuits I had to move more over to the off-grid system than I originally planned.For most homes 3kW per leg is minimal.
I you have the money, buy the 12kW model.
They are stateside@Pete@SolarBatteryBarn: Unfortunately this firmware update did not take and now my inverter is dead. I will reach out to Francis Liang for support. Are they stateside or in china?
Do you have nay other contact info?They are stateside
Sorry to hear
