After finally getting an answer on safely wiring the Growatt spf6000t dvm-us to the grid, I was ready to finish installing this unit in the shop, and now a new issue arises. At 8am this morning, as most mornings, I was checking in with Solar Assistant and noticed no pv production. By 8am the system should be producing around ~1.5k. A quick trip to the shop confirmed no pv production and batteries at 54%. The solar panel icon on the Growatt lcd display was not lit. Pv voltage to the Growatt measured 97v. Cycled pv breakers. No change. Had to turn the Growatt off, wait for it to power down, and restart. Waited till it fully rebooted and turned on the pv breakers. It then recognized the pv input and began charging the batteries. This unit has been up and running 100% off grid since January with no issues ... other than questions caused by a severely lacking manual concerning wiring to the grid and n-g bonding. Nothing in the system has been changed, settings or otherwise.
My search'fu isn't that great as I found a few threads pertaining to the issue but no resolution.
