Hello,
Wondering if anyone has seen this before and if there is a resolution for it. I have 2 Growatt SPF 3000TL 24V inverters in parallel for 240v output. I have a 10k diesel generator as my utility input. Problem is when the battery voltage reaches set point in program 12, the inverter will close the dry contact and starter the generator fine. When power is sent to the inverter, the inverter will immediately open the contact and the generator will shut down. It will continue looping like this until the generator is turned off. Setting for program 12 is currently set at 23 volts. Setting for program 13 is currently set at 27. Generator voltage is 120v and frequency is 60hz. Thank you very much if there's anyone on here that could help.
