drbytes
- Oct 21, 2021
- 113
I'm finalizing my installation and putting in place all the required components to get it pass inspection, so everything has to be to code. My installation now has all the required doodads to pass inspection. So before I invite the pencil pushing civil servant I decided to run trough an inspection as if it were the real thing.
I failed my own inspection when I tested the RCD (ground fault protection?
- When the inverters are not connected to grid and I induce a ground fault none of the RCD's downstream (or upstream) of the Growatts trip.
- When I am connected to the grid, so with the Growatt in bypass, and I induce a ground fault, it immediately trips all the rcd's.
Curiously when I push the test button on the rcd it does trip no matter if the inverters or on or offgrid..
The only variable when inducing the ground fault is the inverters power source, grid or battery.
I have a 300mA rcd between grid and growatt, and I have a 30mA and 300mA after the growatts.
What gives ?
What gives ?
