Hi All,
I have been having issues with the supplied CT (SPH5000 inverter) being inaccurate, tried replacing but still off.
Decided to go down the meter path & at the recommendation of Growatt, purchased a Eastron SDM120CT MV, they sent me the connection details which are pin1 & 5 for the RS485, I have checked the meter is working & I can read MODBUS values from it. Issue is they said to set the meter to ID:1 Baud:9600 (didnt state Parity, default is N) but I get error 401 when I change the inverter to Meter from CT. I have tried all the combos of ID:1 or 2, Baud:2400 or 9600 & Parity: N or E without luck.
Has anybody used a Eastron Meter on there Growatt SPH inverter, if so what settings worked for you?
Thanks
Matt
Thanks
Matt
