Fired up mine a couple of weeks ago and while support is helpful, they do not provide technical information that goes beyond normal usage.
Sometimes, they are simply not sure so this is not a complaint about them, just asking since there are folks here that have learned beyond the manual shall we say.
I notice something that may or may not be odd. I have two strings of 21 panels each. These should generate up to just under 10KW once I'm connected to the grid. Right now, I'm using it off-grid until all the permits/approvals etc are completed. This means I've got it connected to grid but set in self consumption mode only.
Most of the load is handled by one MPPT only, the other is always much lower in wattage usage. Is this normal?
Does the inverter try to balance the PV usage of does it simply use the first string and a little of the second string and as needed, pulls more from the PV.
Thanks.
Thanks.
