I have just started using the Growatt 3000 24V and today I run into another issue...
I have a 24V Lipofe 280Ah battery, Daly BMS (not connected to Growatt)
Middle of day, sun is shinging, grid is disconnected, the battery is far from full and the load is fairly low, 2-300W. The following happens.
0. PV pendles 500-1000W
1. PV =0W
2. I restart (on the 1/0 button) and the growatt starts to charge again
3. 1 hour later same thing the PV goes to 0W
4. Another restart seconds away from 3. and the PV goes to 1kW for another hour or so...
I have a Daly BMS 75A charging 150 Load and Im far away from these numbers and since the PV goes to 0W even if I have a load I assume the problem is the growatt.
I cant find any logic based on the settings to explain the behaviour. The battery voltage is lower than cutoff and a load is connected so why... PV=0???
1. PV =0W
