MichaelRayHam
- Jan 26, 2022
- 10
Here’s some information on my communications configuration: My battery is managed by a Batrium of which is monitoring 8 separate batteries via the Batrium system. The Batrium is communication with my Victron Cerbo GX and is throttling and controlling my charge controllers (Victron) and it is working perfectly, no issues. I am able to see the Growatt inverter output using Energy Meters which are connected to the Cerbo GX, no issues. I am also able to see my AC input into the Growatt inverters should the situation call for grid input. I am again using Energy Meters to communication this information to the Cerbo GX, no issues. The information I need to send back to my Growatt is the State of Charge of the battery. The reason I need the Growatts to see the SOC of the battery is to switch from battery to grid should I drop below a State of Charge percentage that I determine. I would also like the Cerbo GX to be able to show the status of the inverters such as On/Off position, errors, ect. I have two Growatt SPF 12000T DVM inverters running two separate AC load banks Any way this can be done?
