Willowflowage
- Feb 17, 2021
- 30
Moving from golf cart to lithium. 200 watts of solar going to 200 amp Ampere Time LiFePO4 battery. To be used for minimal needs boondocking, say 100 amps a day or less. I will be putting this into a portable tool box for now as a supplement to my still decent golf cart batteries to extend my trips.
This has worked so far on my existing setup with a cheap battery monitor to give me an idea when to cut back on my usage when I hit 12.3 or so volts with the lead cells.
So this lithium stuff sounds like finding the SOC is more difficult and I suppose more expensive to do.
How can I easily and affordably know my battery's fullness at anytime?
I've yet to buy a charge controller but am looking at this one.....
30amp Charge Controller, PWM Solar Controller 30A Fit for MAX 1500W Solar Power 12V 24V 36V 48V Lithium/AGM/Gel/Flooded Battery https://www.amazon.com/dp/B087BC9X4S/ref=cm_sw_r_apan_i_4K1JKYKV8W9EK0X8ZS0V?_encoding=UTF8&psc=1
And will be using this if needed for ac charging....
ExpertPower 12V 20A Smart Charger for Lithium LiFePO4 Deep Cycle Rechargeable Batteries https://www.amazon.com/dp/B082LZNDRH/ref=cm_sw_r_apan_i_ATKPNAJ7FBKY866WS0B9
Any help on what I should do or buy would be great.
