I have a Sol-Ark 15k with two Kilovault 7.5 HABs. Installed Aug 2022 and they WERE communicting, closed loop, until a Kilovault firmware update on Dec 5th 2023.
During the orginal install the provided RS-485 cable was too short. Using a cable tester, I determined the 8 pin cable is just pin1 through 6, straight through , so I used a longer standard Ethernet cable in it's place, and it worked.
In Nov 2023, I had a few Sol-Ark glitches so they updated the firmware and recomended I also have the Kilovault BMS firmware updated.
Kilovault BMS
Old ver // New ver.
Wi-FI ver 1.0.9 // 1.09
MCU1 ver 0.1.15 // 0.1.15
MCU2 ver 1.0.14 // 1.0.26
Kilovault support (Alt-E) has told me I need a new cable and to connect Kilovault pin 1/2 to Sol-Ark Pins 4-5
The cable that was included with the batteries is actually not the correct cable for the 15k Sol-Ark. The pin out needs to be changed for the cable and the included cable is probably not going to be the best option.
The Sol-Ark 15K uses Pins 4 and 5 (Can Hi and CAN Lo)
our HAB uses Pins 1 and 2 (Inverter Comms)
Really, a firmware update, and I neeed a new cable? I went ahead and made a custom cable and it still doen't work.
So, does any one have Sol-Ark to Kilovault closed loop working? If so, what cable pin out are you using and what firmware version do you have?
