Hi everyone,
I give up on trying to find an answer online and read many informative tips on here in the hopes that someone might know the fix/or not?
My Epever 4210AN is a year old had issues with charging the Lifepo4 Screampower 12V 100A eventually got it sorted (no thanks to Epever) but then it would occasionally stop charging even though batterie not fully charged so a re-boot corrected that (2x) To cut things a bit shorter the other morning I noticed that the panel was 3/4 AM sunlight it was only producing 0.9-1.5W on a 320W mono panel (brand new) I am still new to solar but that seemed off to me thinking that my controller is messing up again, so I went to re-boot it disconnecting panel first and then while pulling the batt negative out of the controller I accidentally touched the positive lead creating a brief and small short, after re-connecting everything again everything was dead, battery down to below 1V no PV power nothing, so I plugged in the (supplied) charger to the battery and it immediately came back up ( i did for the first time run the battery down to 10,6V and turned inverter of) ever since nothing from the PV no voltage /Amps nothing and in night mode(moon). I hooked it up to my other system and all is well it started charging etc..so it seems that somehow I killed the BMS which should have prevented that tiny spark from causing harm (the one good thing about Lead Acid that doesnt happen) Now the charger can after 20hrs bring the battery to 13..5V not more ,before it would go to 14.7V and shut of. I cannot figure out what went south? I know its the battery as the controller works with the LA batteries but nothing on the Lifpo4. Anyone ? I do not want to spend another small fortune(CDN$) on a new battery as this one is only a year old. Thnx in advance to anyone with an tip.
