I’m planning a new DC-coupled array based on half-cut panels which will suffer from partial shading.
I’m hoping to use 3S strings and as I’m understanding the interaction of shading, bypass diodes, and half-cut cell panels, I thought I share what I’m coming to understand as far as the requirements that places on Vmppt range of an MPPT charge controller.
Half-cut panels change the equation because if a panel is only shaded on one-half (upper or lower in portrait), they can put out Imp/2 @ Vmp.
So if you have a string of 3 panels where 2 are ever half-shaded, you want your MPPT to run at full 3x Vmp and half-current (Imp/2) for ~1/2 max power instead of cutting out both shaded panels using bypass diodes which would result in only ~1/3rd max power.
So what happens when 1 panel wants to pass twice the current of the other panels?
It will increase panel voltage beyond Vmp and begin approaching Voc to the point that current is reduced by half.
If we make a simple linear model of Imp @ Vmp and 0A @ Voc, voltage will increase to at least Vmp + (Voc - Vmp)/2. Since the actual power curve extends out past this linear approximation before dropping more steeply, the actual voltage needed to drop current to Imp/2 will be slightly higher than this estimate.
So the power being output from the unshaded panel will be reduced from Imp x Vmp to > Imp/2 x [Vmp + (Voc-Vmp)/2] which will be somewhere beyond half max power.
What this means as far as an MPPT controller is that it must have the range to extend to 3 x Vmp + (Voc-Vmp)/2 in order to fully-extract this available power.
My 450W panels are 41V Vmp and 49.6V Voc, so I need the Vmppt range to extend to at least 123V + 4.3V = 127.3V.
But on a cold day, Vmp can be as much as 43.6V and Voc can be as much 52.7V so I’d ideally like an SCC that can control Vmppt all the way to 130.8V + 4.55V = 135.35V.
Epever’s 200V MPPT charge controllers control Vmppt to 144V and WZRELB’s 170V MPPT controller control Vmppt all the way to 150V, so looks like either will fit the bill as far as controlling 3S strings of these 450W half-cut panels with partial-shading.
But this is another constraint to consider when planning an array of half-cut panels which will be impacted by shade...
