Hey all. As the title suggest I just built a portable power station. Its a vatrer server rack battery and powmr 5k low frequency inverter.
I'm having an issue where I believe the BMS is cutting off and will not start the inverter unless I connect grid power first.
From my limited investigation it's because the inverter is pulling too much power to charge the capacitors so I possibly need some sort of pre-charge circuit. It works fine if I connect AC power first but I don't want to have to do that obviously. Any help would be appreciated. Just need to know if I should return this inverter. Thanks
