Hello, all!
Building a hand truck portable power station to take on camping trips and other backup uses. Big difference in my idea is to use the mounted batteries daily in my home setup and just disconnect whenever it's needed to go offsite. For my home setup I have 4 server rack batteries in a cabinet and a 18kPV inverter. For hand truck, going to use 2 batteries and an old off-grid inverter. To clarify, for daily usage the mounted off-grid inverter is going to be inactive so I'm trying to find a way to connect hand truck through DC means to the home batteries (through busbar for example). Either that, or use the 2nd port in the 18kpv. Some sort of quick connect method is what I'm looking for. Also, can battery be connected/disconnected when system is running? Any ideas or thoughts would be greatly appreciated! Thanks.
