Harbor Freight 100 Watt Solar Panel Kit
Delmar
Lake Conroe Texas
Am seriously looking at the Harbor Freight 100 Watt Solar Panel Kit to supplement the 400W HQST poly panels on my golf cart during a hurricane. Why I am so interested:
  1. I understand amorphous panels work better with clouds. Can anyone confirm? After a hurricane it can be cloudy for a few days and noticed the poly panels have reduced output.
  2. Cheap, can buy 100W for $160 using my 20% coupon including connectors and lights. Inexpensive toy learning experience.
  3. Flexibility. Includes four panels that I can wire in series for my 48V golf cart, or wire in parallel for my 12V office battery.
  4. Lightweight and portable with integral mounting stands. The four HQST panels are heavy if I buy a 2nd set.
My MakeSkyBlue SCC has a 2nd set of terminals to easily connect the HF in parallel and not use the crappy supplied PWM.
In my experience with HF is there stuff works but not good for long time use. If it meets safety standards, it's at the lower end. For testing and learning it's a cheep wat to go but when you are ready to build your finished system don't use any of that HF stuff.
My two cents.
Dan
My low expectations will be inline with the low price. Do you have direct experience with the kit?
Someone gave me some panels that look like those. They are several years old. Measuring them and looking up current panel sizes of this type, they should be 20-25watts each. I have three of them. One has zero output and no sign of a broken wire. The other two combined are about 12watts (together!!!). They look okay but just don't output anything worth the space.
There is a HF in my area not too far a drive, and when I went to check them out, (the 4-panel 100-watt kit) it was very heavy. I was like, "wow! no way!" And they were large for the size and weight and wattage I could not justify getting them for my purpose and use. I just recently purchase the Windynation online for in-store pickup at Homedepot.
Yes just for testing and learning, will be stored in the garage most of the time. Plus the very rare hurricane that knocks out grid power.
WindyNation panels are the same price as my HQST, but at 8 lbs are about half the weight. Wish I would have seen those first.
And to clarify above: can buy 48V for $160 using my 20% coupon. Otherwise would require $300+ for conventional panels but I would also get 400W.
Still would like feedback on amorphous panels, regardless of brand.
Saw that HOME DEPOT has a NATURE POWER 180 watt panel with a 12 amp PWM Controller on sale for a lot less money. Anybody have feedback on the #50180 panel???
That seems like a great buy. Anyone have an opinion if not any experience?
I would take the HD kit over the HF kit any day. I wouldn't try to charge a flashlight from a HF solar system. Seriously, most of their stuff that involves air or electricity is crap. I've tried a few air tools from there and finally gave up and bought quality Bostitch equipment. The few things I buy at HF do not involve air or electricity. Nitrile gloves, tire chocks and hand tools that my life doesn't depend on.
Harbor Freight knows it's lane, and you should know it too. It's cheap, and it's cheaply made. Good for some things, not for electricity.
I have that HF 100 watt system. Let me answer generally first for all interested readers, and then about your specific application.
If you knew absolutely nothing about solar and wanted to learn what lowest end solar panels are and what a lowest-end PWM charge controller is, this might be the thing. But if you wanted to actually accomplish much more than powering the 3-watt 12v light bulbs, save your money and buy better stuff. It really is a toy. I paid $144 for mine on sale a few years back, but then you need a battery and an reasonably sized inverter and some cabling if you want to use the power at night and use AC power, so then you're in for couple hundred more dollars.
Here's why it's bad:
- the solar panels have plastic frames. they will easily break if you try to mount them. tighten a screw too tight through the frame and it cracks. real solar panels have metal frames
- at 7200 feet in the sunny, clear sky desert and 2 years of using them, my 4 x 25watt panels combined together have never put out more than 34 watts total. The most they have ever generated is 230 watt hours in a day. That's not enough power to do very much. It will run some 12v lights, nothing much more.
- the manual for the charge controller is useless. I still have no idea what the various modes are. I now I just use charge controller as a DC switch and don't have it control any battery charging.
- it's bulky for what it does.
- when it's cloudy is produces almost nothing, even tho amorphous is supposed to be better
- in 18 months of using panels and logging the data, they have produced a total of 48kWh. So in a place with 300+ days of sun, I'm averaging less than 90 Wh a day.
If you want it as an emergency lighting system, to charge a phone and a laptop, it can do that.
So now my question is, why do want to run around in a golf cart during a hurricane?!
But seriously, for your application, I think you can do better. I've not run mine in series so I can't speak to that. Good you are not thinking of using the supplied charge controller. The panels are heavy for your application, about 10 pounds each and makes more like 8 actual watts per panel peak sun rather than the nominally rated 25. I don't think you will get much usable production if anything on cloudy post-hurricane days. Not enough to do much with a big 48v golf cart battery bank. I haven't had a cloudy day in the 30-day look-back period to verify, but if I recall correctly I get like 40 Wh total from the 4 panels combined on a cloudy day.
Hope that's helpful.
The HF glass is weak and the plastic frame doesn’t hold up well. I have two cracked panels but they still work. Wouldn’t recommend.
Will Prowse has some videos of inexpensive and easy to build solar systems, that can actually produce a fair amount of power. As for myself, rather then get several of the cheap 100 watt panels, I got myself 2 new 335 watt solar panels (I'm only currently using one) for $110 a piece.
Santan Solar has a solar kit, that includes a quality mppt contoller, one 250 watt solar panel, mounting brackets for the solar, wiring, and manual circuit breaker for $165.
I always laughed when I saw the solar panel kit at HF. Just having done research on solar panels for my home, I could tell that the panels were too big and heavy to be quality products. Thank you @PatBlack for sharing your experience and confirming my suspicions.
There are several brands of solar suitcase available that would be a nuch better choice. I know of several people who are satisfied with the Renogy kit.
I bought the HF kit last year to charge a battery to run a CPAP machine in the Mohave Desert. It worked for my application, but yes - it's a toy. My 100 Ah flooded lead-acid battery lasted the two nights I needed it, but the output from the panels was inadequate to top it off each day.
The manual for the HF kit advises to expect a drop of 25% in output after six months. The open-circuit voltage of the panels is about 25v, and best power (or "least-worst" power?) happens at about 18v. The PWM controller doesn't tell you much about what's happening; I use mine in the second mode, which essentially tries to charge the battery to 14.6 volts (but can't actually get there.)
Given their inconsistent performance panel-to-panel, I would expect putting them in series would be a really bad idea. One of the panels with an appropriate regulator might be nice for charging a cellphone in the wild. If adding a big, 10-pound, fragile panel to your pack was something you really wanted to do.
On a positive note, the blue LEDs on the panels look swell at dusk.
1 100w mono panel 15lbs and an inexpensive PWM charge controller maybe 16 oz. $100+$20=$120 16lbs total plus two 20’ lengths of 10g solar wire with connecters maybe $10=$130
vs 4 heavy weak cheap disposable panels that produce laughable 100w of power all together $180........
Use the extra $50 you’ll save towards a Walmart LA deep cycle battery.
Learn solar basics with the choice that produces enough power to charge a useful battery and will last for years. ? My.02
Thanks everyone for the very helpful comments.
Per my OP the panels are to supplement my four 100W HQST. Intent is to learn if amorphous panels work better with clouds. Looks like not.
During a hurricane and extended grid-down will power the cart FLA battery set and my 2700W UPSverter. For more detail click here.
The user manual explicitly states do not wire the panels in series.
Not being able to connect in series for 48V to my SCC is a deal breaker. Unless it meant the crappy included PWM cannot handle panels in series.
Yes...agree. The four panels are relatively very heavy. And the four panels together are considerably bigger than a single 100 watt panel. I have the kit now and am upgrading currently.
