billynoah
- Nov 16, 2021
- 17
A friend of mine was given 6 x 25w / 18v harbor freight solar panels - probably the same as these: https://www.harborfreight.com/100-watt-amorphous-solar-panel-kit-63585.html
Neither of us have ever built a system but this seems like a fun way to learn some basics.
The panels presumably came as part of a kit but we don't have any cables, charge controller or any other equipment, so that brings up some questions.
It looks like the kit originally consists of some kind of combiner cable like this: https://www.amazon.com/ELFCULB-Splitter-Extension-Polarity-Motocycle/dp/B0BKPJYFMJ/?th=1 and a charge controller like this: https://www.amazon.com/Controller-Intelligent-Regulator-Paremeter-Adjustable/dp/B08L8TBCK6
As I understand it, that will result in max 150 Watts @ 18V.
I could potentially buy these components but there are 6 panels and I have not seen any 6 way connector. My initial question now is: what is the best way to connect these panels?
Can they be connected in serial and hooked up to a charge controller capable of taking 108V? I haven't been able to find anything online about serial connections for SAE connectors which is confusing since most other larger panels I've seen use MC4 connectors and are connected in series. Is this even a good idea? I figure at the most basic level, the wires could simply be brought together with wire nuts or something but I assume there is a more conventional way to wiring this array.
Alternately, is there a sensible way to connect all 6 panels in parallel? What kind of cabling should I be looking at? Can I buy two 3-to-1 combiners and then a 2-to-1 to run all 6 in parallel? Is there a simpler way?
Essentially, I'm looking for some input on best practices and components to consider for this small learning experiment.
