bennetimo
- Jul 30, 2021
- 15
Hi all,
I have an inverter with a single output socket (and no hardwire outputs), and it has very little information about how it is setup for grounding/bonding. I would like to have a couple of AC outlets run off the inverter so that I don't need to use an extension socket. I've been trying to digest all I can about gfci/rcd/grounding setup for inverters but a couple of things I'm still hoping to get clearer in my mind.
1. If I can plug an extension cord into the single socket of the inverter, is there any difference between that and hardwiring a plug going to a couple of sockets? It seems like it should be the same to me, aside from maybe giving the impression to someone who didn't know the setup that they could plug multiple high load devices in simultaneously. But if you had some hardwired sockets and only used one at a time, is there any problem with that?
2. When is it necessary/recommended to use an RCD (GFCI) or not with hardwired AC circuits? If I plug in directly to the inverter socket there isn't one, but most seem to add one when hardwiring sockets. From what I understand if my inverter doesn't have an NE bond internally, then an RCD wouldn't even work. What do I do if I don't know if my inverter has that bond or not? The inverter I have is this Renogy 1000w one and it doesn't say anything in the manual about the grounding/rcd internals. I'm in the UK and there is slightly more information on the equivalent US one, which mentions it has an in built GFCI. I'm presuming my unit has some internal differences.
Apologies if this has been asked before. This is for a van that has no shore power hookup, so it's the only AC system. I've tried contacted Renogy support multiple times now, and have yet to get a single word back from them!
Thank you!
Thank you!
