Has anyone else had issues with MPP Solar LVX6048 Battery Terminals? And also fan direction..??
yrksolar
So I'm about ready to implement 3 of the MPP Solar LVX6048 split phase inverters.
I happened to find this post, and I believe 1 or 2 others where the battery terminals seem to have a cold solder joint, or possibly just where soldered correctly:
I plan on having a friend of mine redo the solder joints on them, and maybe add some potting to keep them stable when installing.
While I was taking 2 of the 3 units apart I noticed that the fan direction is actually pulling the hot air from the transformer and all the other components DOWN and out the bottom. (Note the fans are mounted at the bottom of the unit)
This seems very counterintuitive to me as you would think you would want to bring in the cooler air from the bottom and blow it out of the top of the unit.
Maybe I spent too many years building gaming computers :P
Thank you sir! I also just ordered some copper bus bars to replace the aluminum ones.
I also hear people comment on the noise that these make. Having not installed one yet, do you know if it is transformer noise, or fan noise, both?
I can always find some quieter fans I'm sure if that is one of the culprits.
When I was running my TP6048, same inverter, the fans were high pitched screamers. "Transformer" noise was minimal in comparison.
Thank you! Just the information I was looking for.
When I find something better i'll be sure to post a follow up thread.
I think i'm going to flip them so they are pulling in cool air from the bottom, and possibly add two more at the top to help pull the hot air out.
They are deep which is good for static pressure.
see my build thread about the same issue with all these "Voltronic Axpert Max" clones (I'm using EG4 6500EX-48, but the same with MPP Solar LVX6048). Beside my active cooling with a ducted mini split, the easiest thing is to 3D print some 45 degree windshields placed on the sides to separate the hot rising air from the bottom air outlets a bit from the upper cold air inlets. This will give you some positive cooling effect!
