Here’s a response I received while asking awhile back:
the normal ESS grade cells not grade A , they are just grade B cells(but new, no used, good performance for 3-5 years, after that then will have some unstable performance)
the true ev grade A cells cycles around 10-15years
I would expect the C rate to higher on the ev grade mb31, i.e. .5C for the ev grade cell and then maybe 0.25C for the random 280Ah ess grade cell they would use by default (prob rept 280ah if their cell pricing is anything to go by). Maybe moreso for charging?So, she explained the difference between the 2 batteries are the capacity and the c-rate. The 280ah battery is .5 and the 314 MB31 is .25.
I’m not well versed on this, but understand it’s the discharge rate. Am I still good with my 48v system? The 2 batteries will be 314ah / 16kwh each, so somewhere around 32kwh. My inverter is only 6,000 watts. The most I’ve seen pulled on the system was about 3,500 watts.
Will this .25 vs .5 affect me?
Which direction did you end up going? I recently came across Avepower as well.Thanks for the advice on the BMS and cell grade. I have 1 estimate with Docan at the moment and waiting on one more quote from a company named Avepower. Both claim A grade cells.
The few persons I had interactions with at Docan seem to be decent folks.Ended up buying batteries from Docan. Had them upgraded with new MB31 cells.
