Greetings all! Been lurking for awhile, learning as much as possible and about ready to pull some triggers here. However, I'd definitely appreciate some feedback/suggestions/thoughts on what I'm about to try and do here.
My application is for a ~30ft RV I will be living/traveling in for the next year or two while working remotely. I expect a fair amount of boondocking in shady areas and I will mostly be working (graveyards)/traveling at night so I don't think solar would be worth the investment for me. Most of the builds I'm seeing incorporate solar, so I'm not certain my plan is feasible now.
I'm interested in going with either a 4 or 8 cell 280/302 LiFePO4 build. My power needs while working are likely in the 11 to 15 amp range for 10 to 12 hours, 4 days a week. I currently have a 3200W inverter generator I'd plan on using for charging when shore power isn't available. If I'm doing math right, that'd be 11ish hours for 4 cells or 22ish for 8 cells...which, isn't ideal.
I've read that as an alternative, I could do a DC to DC charger with an upgraded alternator in my truck (60A Renogy or even 120A with 2)...so I'm considering that maybe I should build them as portable battery packs that I could swap in/out of the truck to do the bulk of my charging instead?
Next issue is powering the RV 120V system, I'm looking at a 2000w/3000w inverter. I currently have the WFCO-8955PEC power center. If I'm going to have to do the bulk of my charging using my truck, does it make any sense to upgrade it to the Li compatible one? Is there another way for me to be able to charge the LiFePO4 packs using shore power when I have access to it while also powering the RV?
Or, is there a better way to go about all this that I'm missing?
