Hello. Just another newb dropping in for a quick sanity check ...
I have the following system just purchased and put together:
- TimeUSB 12v 140ah BT LifePO4 battery, 150amp BMS, M8 bolts
- Alffaa 12v 1500w Inverter
- Bay Marine Supply MRBF Terminal Fuse Block Kit with 175a fuse
- iGreely brand 2ft 2AWG 5/16 lug battery cable, tinned copper
I've tested this setup with a Keurig coffee maker, a dual speed ceramic heater and an electric water kettle. Everything appears to work well, no overloads, but the temps on positive side battery cable and fuse block are concerning.
Last test was running about two minutes with the water kettle which was pulling 1535w and 118amps at battery via Bluetooth app stats and 1252w at Inverter. Using an infrared temp gun, the positive side cable closest to battery was showing 150F, wire slightly melted just below ring terminal and the fuse block itself read 185F just below the fuse. It was only 110F on top of the positive side of battery where fuse is bolted into. It appears most of the heat is originating from the fuse block (?!?)
I went with 2AWG over 4AWG to pull more amps if I need to, but use case for this setup is NOT for continuous 1500w loads. I just wanted to test the max and see how it holds. Battery and inverter runs well, just a bit concerned about the temps here.
Thoughts? Thanks in advance.
