Bosch/Mitsubishi heat pump(standard heat pump, not mini split) has been GREAT for years, then inexplicably in one month power consumption shot up.
Nov 2022
243kwh
Dec 2022
321kwh
Jan 2023
415kwh
Feb 2023
352kwh
Nov 2023
349kwh
Dec 2023
307kwh
(basically stopped burning wood here, Jan 2024 bump is expected)
Jan 2024
512kwh
Feb 2024
398kwh
Nov 2024
412kwh
Dec 2024
697kwh - wtf?
Jan 2025
661kwh
Feb 2025
529kwh
Monthly average temps have been the same year to year, less than a degree of difference. Only minor changes to house insulation - to ADD insulation. Air filter is kept clean.
Heat pump seems to turn on the compressor and air handler fan, run until house is up to temp, then the compressor turns off and the air handler fan keeps running until the house is cold again, then starts the process again almost immediately. Didn't used to do that. Non smart non internet connected thermostat.
Edit to clarify: Air handler fan does turn off, it just runs for so long after the compressor turns off that the house gets cold again, then turns off briefly, then restarts the process. Air handler fan probably running 30 minutes out of every 40 minute span, even when outside temp is 50F and inside temp is 67F.
Before I call a tech out to take a look, is there anything else besides double checking the filter that I should take a look at?
Nov 2022
243kwh
Dec 2022
321kwh
Jan 2023
415kwh
Feb 2023
352kwh
Nov 2023
349kwh
Dec 2023
307kwh
Jan 2024
512kwh
Feb 2024
398kwh
Nov 2024
412kwh
Dec 2024
697kwh - wtf?
Jan 2025
661kwh
Feb 2025
529kwh
