Zwy
Emperor Of Solar
The water heater will actually cool the area and your mini split will use less power when running in AC mode.Do any of these run off of external air? It doesn't make sense to use heated indoor air here most of the year, since we use the mini split in AC mode for a week or two, tops.
I should really stick a power monitor on my electric water heater circuit, see how much it uses to heat vs stay hot.
You can run vents to anywhere you want. Personally, I don't worry about it. I have mine in the un-insulated basement and it keeps the basement cool in summer with low humidity and no need to run a dehumidifier. The shoulder seasons the basement will be around ground temp at a minimum. In winter, I have an electric radiant heater on a Shelly smart plug and if I will hit close to full charge for the day it is turned on during the day.
If you are running the mini split without using grid power and the heat pump water heater is using some of that heat energy from the mini split, what difference does it make as the heat energy doesn't cost anything?
