may i ask about your thoughts on wood gasification approaches?
Originally it was developed in Finland like 500? years ago due to the king’s decree because of the wood shortage at the time. I think they did 4 or 5 stages of “burn” where a large central masonry ‘oven’ would be used for a short extremely hot fire in the morning and the masonry would radiate the heat throughout the day.
This type of wood heater today is commercialized under the brand name, tulikivi
https://www.tulikivi.com/usa-can
Unfortunately, the several excellent resources on building these and their historical development that were easily found on the internet in the 90s have disappeared from availability following the globalizing of the brand name of the manufacturer. It’s not their technology, however.
Gasification was used to run internal combustion farm equipment in the early 1900s btw, with much use during WW2.
The ‘three chamber burn’ I referenced is essentially a gasification wood heater. How they figured that out without today’s tech and reference blows my mind!
In process, the science of it is leaned on with modern wood stoves that use air tubes whose output stream is directed across glass-front doors and market as self-cleaning glass features- but in reality this increases the burn of secondary gasses although not nearly as fully as a three-stage burn.
A three-stage burn will achieve 2300*F at the final burn, the ‘wash’ air types may be only 1000*F or so- not much different than a ‘normal’ wood stove. Plus, I’ve seen the wash-air types when glowing super hot and ‘gasifying’ actually accumulate these super-hot gasses and when it is windy create cyclic positive and negative pressure on the chimney and then the sudden introduction of more air will combust the gasses in the stove and chimney (explode) and blow the mortared-in chimney thimble right out with a large sooty fireball across the kitchen ceiling resulting.
Yes, I’ve actually seen this happen.
been reading about catalytic combustors and they say 30% of wood energy gets wasted via unburned wood gases going up the chimney and contributing to creosote buildup
There is no doubt that catalytic stoves can be more efficient- but they have three faults that annoy me. One: you have to insure catalytic burn only happens once the firebox is like 900*F+ Two: the catalyst doesn’t last nearly as long as typical marketing claims. Three: even the ‘automatic’ designs are fussier than a 10kW lead acid battery bank. Bonus: the catalytic wood stoves do not reach the efficiency or overall high temperature of a true gasification/three stage burn.
I’m no thermodynamics engineer but the 30% and other claims I think are opportunistic market from an unrepeatable by consumer lab test.
And THAT is just about the limit of my knowledge.
