Slept at my cabin the other night with temp down into upper 20's. havent gotten the wood burner installed yet.
I took my big sleeping bag and this new heated mattress pad to use on the bed. Figured it was going to be a long night.
Turns out it was great. went to bed in my sweat suit and with this heated mattress pad I had set on #5 of 10, i was out of my sweats in a hour and had it turned down to #3 for the rest of the night.
Much warmer than using a electric blanket over the top of you. Ran it off generator this time. I need to stick my killawatt meter on it and see what it draws and run off the batteries next time.
Well worth the $49 cost for the twin size. This particular brand is like a fitted sheet and not just a loose pad that will slip around and move out from under you. Also has a auto off up to 10 hr timer. A lot only run for 2-4 hours before self shut down.
