GyroGypsy
- Nov 22, 2019
- 29
I tried using Facon ST725 tank heating pads, mounted on .020 aluminum panels, tightly sandwiched between batteries. I found they were short-cycling, only remaining on for about a minute every ten minutes or longer, while the insulated battery compartment temperature dropped. I am using two Tesla S modules. I used heated antifreeze for first two years, but some particles appeared in the fluid and blocked the internal passages.
I read the thread here about cutting out the internal thermostat, and using a stand alone controller. I am worried about pad damage while peeling the adhesive backed pads from the aluminum. But that would be my next step.
Anybody else tried using tank heaters, or have other ideas?
