I have placed 30*30cm heating pad in the insulated battery box, then 1mm aluminium plate on it then LFP battery on top of it.
Temperature is regulated by simple thermostat, like this. Temp sensor is taped on aluminium plate.
This pad heats up a lot and fast (300-400W). So i use setting to start heating at 7C and end at 10C. But the temperature on the aluminium plate rises even after that to around 15C, before all the heat reaches sensor.
How do you think about my setup?
