Just an FYI post in case someone wants or needs to know in the future. We got a 40 gallon AO Smith heat pump water heater. It speaks modbus but I haven't dug in to it yet. I replaced the 4400w water heater elements with 1500watt elements so that even when they run it won't significantly load the inverters. You can put it in electric / heat pump / hybrid mode. In heat pump mode it pulls 360w (measured), pulls 1860w with heat pump and elements running.
We also got a Mitsubishi 3.5 ton ducted mini split. It replaced the ducted conventional 5ton heat pump we had. Most of the time when it runs it pulls 800w. The most I've ever seen was about 1200w. If it was ductless and used a conventional wall mounted indoor unit it would be 26seer... but it's 16 seer as a ducted unit. Although I don't get the efficiency out of it with the duct, my house was already setup for the ducts and I have too many rooms to have a head in each. The value to me is that it soft starts. We got down to 14F (record cold for where I live) and the unit was able to run at a 50% duty cycle. Flipping awesome.
A buddy got pioneer 1 ton (12000 btu) units in his tiny house and each seems to pull 170w most of the time.
Just general info.....
