I dont have any cells on hand to measure the height of the 280-320 class blue alu cells - does anyone have an accurate idea of the height above the top of the cell?
one more question if you will.......are the 280 - 320ah LFP all the same dimensions ? I realise the connector on top may be different according to what was welded onto the top of the cell. So while that measurement may vary, I would think the length, height, width etc. wont change at all.
Get the most out of your energy needs with EVE Batteries and eve cells. Power up with our high quality LiFePO4 batteries for efficient, reliable and economical power! Get safe, durable solutions―get EVE Battery cells from Evlithium!
It does sound like the only safe bet is to acquire the cells first and then measure and build around it. They *should* match a data sheet but who knows when new models of battery get inserted into the supply channels and upon arrival we get a little surprise on the dimensions....may only be a few mm's but that might be too much in a tight fit and I do have a very tight fit coming up.
