vk2emp
- Mar 2, 2020
- 101
Got into solar when a mate bought a 200W folding panel with a crappy pwm controller on the back. Did my research and settled on a victron 100/20 for his setup. Wired the panels in series and his AGM's charge a lot quicker now.
Since seeing Will's videos, in an ever expanding quest to learn as much as I can about system building and maintenance, and yes I have made mistakes (buying 4 CALB CA180FL's from a local supplier instead of getting a better deal on bigger cells from alibaba).
Presently I have the following stuff set up:
Victron 150/35, connected to 500W of Monocrystalline panels, keeping the CALB cells topped up. I have another 1500W of panels for when I expand to a 48V system.
Victron 48/3000, patiently waiting till I get a 48V bank
A giant ups connected to 16! SLA batteries, this system is going to be retired once the 48V solar is commissioned. The batteries are stuffed
A raspberry pi setup to monitor the batteries and solar charge controller. A quick test with the inverter on the ups bank shows that also works as well and shows up on the 7" touch screen.
Since mine is a house setup, I will need to implement a way of charging the batteries that can be controlled by the BMS I have chosen to use, which will be the REC SI BMS (it talks victron).
My setup is NOT cheap, and I don't have any problems with folks doing it on the cheap, I just like the victron gear. The CALB CA180FL's will be repurposed as a portable camping pack, with a spare 100/20 charge controller, 270W panel, and a Dali BMS. Since the mac draw will be 25A, a 50A Dali should be fine.
Background:
ham radio operator, was taking stuff apart at age 7, and playing with electronics at age 10.
Background:
